Ram Limited with LED headlights turn signals issue.
Loki0005
Canada
Hey all
My Gen 5 limited with projector LED headlights with integrated turn signals has an issue. The turn signal on the drive side front has stopped working. I have done some googling and have not seen any solutions other then replacing the entire head light assembly. Quick call to the dealers tells me that's a 1200.00 touch for the part alone.
Before I punch my self in the face and order one , is there anything else that I could be missing?
Truck has 70K on the clock. No rust or corrosion that I can see on the connections to the head light.
Thanks in advance.
Loki
Streetsport
Colorado
Could check voltage at the connector, bcm should have a code stored in it if there is an issue if you have a decent scanner
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Those light rarely go out, you can break them but it's highly unlikely it just stopped working.
The advice given so far is on target. Check for codes then make certain you have power. My bet is on a bad ground. I would also load test your battery just to be safe.
TRK_GANG74
Navy Badge
Va, Hampton Roads Area
Hey all
Thanks in advance.
Loki
There is nothing you can do but have it changed. Both of mine have been changed due to the drivers side having the white DRL strip go out then 1 1/2 years later the passenger side turn signal went out. Both were due to an internal short. Luckily my extended warranty took care of both replacements. No codes were stored but I did get a front turn signal out message on the center cluster screen. My battery was good and so were all the grounds.
Dredger
SE Ohio
Hey all
Thanks in advance.
Loki
If it comes to replacing, check with Benny @AllMoparParts.com
He could have a better price than your dealer ;)
EDIT - I see your in Canada. That may not be an option :confused:
Dodge 1500 4X4
Rochester, NY
It's a sealed unit you have to replace the complete Assy.
Kmiko
