2016 right rear turn signal hyper flash issue.
Brain Health
New Hampshire
Hello, new here and as such 1st post.
My 2016 Ram 1500 right rear turn signal started hyper flashing. Dash says the light is out. But it is not.
I have the led taillight assembly.
Things I've tried. Take the assembly out and unplug and clean all connections. Take the negative cable off to hope for a reset. Pull and check all fuses attributed to the lights/signals. Buy a brand new tail light assembly and install it. None of these potential solutions worked.
I sure would appreciate any input from fourm members that have had the problem and how to fix it.
Thank you.
1999 White C5 Coupe
Thank you.
Check both brake light bulbs in the center, high mounted brake light for correct operation.
If one or both bulbs are burnt out, it can cause the dash warning and erratic turn signal operation.
oldroy61
Celina, OH
6.7 Turbo Diesel
I did alot of those things plus the Alpha OBD and turned on the LEDs.
You'll learn to ignore it.
But if you haven't you can try Alpha OBD turning on the LEDs.
noraa73
