Ram won’t start
Nosaj80
Illinois
5.7L
when I turn the key to the on position there is no click & you can’t hear the fuel pump kick on. Battery is good, starter is good, fuses & starter relay are good & all battery connections & grounds have been cleaned & ignition switch is new. Any suggestions?
cheffrank_357
US
hem 5.7
Pull the codes
Could anything from starter to relay to gear shifter sensor
Check first if it turn over by jumping the starter with a screwdriver (make sure its in park and verify underneath also do a parking brake and a wood chock)
If it turns
Try it with key on
If it starts its something to do with ignition switch
If it dosent turn its the starter or relay
Or the battery
Always charge the battery first and check connections
It could be its got enough juice fo that but not enough for the 600 amps to the starter
Good luck
Sent from my LM-Q710(FGN) using Tapatalk
Dan98
Please elaborate does it turn over?do you have power to dash like radio blower motor? Or did the fuel pump just quit working which is very common?
Sent from my SM-J260A using Tapatalk
Steve58
