Rear 02 question
night hawk
Rockport, Texas/ Wylie, Texas
Just got my headers on. im still using cats but no 02 **** in/after cats.
How do I turn off the check engine light and delete rear 02's?
Thanks everyone!
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
You are going to need a custom tune to turn off your rear o2 sensors. Are the rear sensors damaged? I would just plug the sensors back in, and throw a set of non foulers under them if they still trigger a code.
truckin151
2013 sport
you can try wrapping them in tin foil and tucking them up and away, the non fouler truck works most of the time, to but there are some stubborn trucks out there that need a tune too turn them off
Blackram
Thanks everyone!
If you are still using cats then weld in a couple bungs and plug them in.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Agree'd if you have cats then install the sensors.
night hawk
night hawk
theyre sweet! i have magnaflow cats, x pipe, and two 18" hedman glasspacks. it has a very mean sounding low rumble at idle. it really sounds good at WOT. and i noticed a little more bottom end power as well as quite a bit of top end power! overall, VERY SATISFIED with my new set up!!!!!
