Rear end shimmying - 2015 RAM 1500
cat27
Louisiana
This is my first thread post, so bear with me please. I recently was told the rear end had to be rebuilt. This was done a few weeks ago but I'm still hearing and feeling what I call a shimmy in the rear end. Today was the worst and it happened when I backed out of my driveway this morning. I tried a few minutes later to duplicate this but could not. I'll try again tomorrow morning. In addition, when I turn sometimes, left or right, I can feel a shimmy/vibration while turning. The work was done by a local RAM dealer. I sent them a message but have not heard back. A few months ago, before the rebuild, they replaced the pinion seal and sleeve, but I had to return after that work because the rear end was making noise, and they confirmed they had not installed enough of the slip additive. Once done it seemed okay. Could they have once again failed to put in a sufficient amount of the proper fluid. Any thoughts would be appreciated.
RamCares
n/a
n/a
Greetings @cat27! Our team understands if you would like to continue troubleshooting with the rest of the forum community, but should you decide to revisit the dealer regarding this shimmying concern described, send us a private message. Our team is always one PM away!
Hannah
Ram Cares
Daw14
South Florida
He comes here because of incompetence at his dealer,he’s trying to be an lnformed consumer ,which is great for him ,but not good for companies that lack ???? Maybe trying another dealer will get you a tech that knows rear end work . Good luck. Find an independent mechanic,you will be better off in the long run.
C
cat27
Louisiana
I'd like to thank the RamCares team for getting involved and helping me. The dealership did finally step up and get my truck gears properly installed. I'm glad I decided to post my problem on ram forum site. Take care, and again, hats off to RamCares staff !!
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
Glad you got it fixed, and thanks for coming back and letting us know. Did they say what exactly they did wrong?
rockyj69
