was working on doing a level kit which requires the air line to be removed and replaced after a leveling puck is installedWhat are you trying to accomplish by doing this?
Purge and refillThe air ride system is charged with nitrogen to keep moisture out of the system. If you remove air lines, are you planning to recharge the system with nitrogen? Moisture will kill air suspensions.
