I used kyb monomax 565038 and 565127 for a 2/4 belltech drop. One is a stock length that will for the front, the other is a little shorter to work with the rear drop. Fyi when you install the rears install the top bolt before cutting the strap, otherwise you'll be using a floor jack to compress the shock.
The monomax rode really well, much firmer/more controlled than stock or belltech. I'd put em on a stock truck, I was impressed.
yes you can use Airlift bagsThat looks good. I can still use the Air Ride kit with the rear drop, correct?
