Remote start
Villanova
Is there any way to increase the idle RPM's on a remote start or just starting up. I understand that letting it idle at low RPM's will hurt the engine?
62Blazer
Midwest
Assume you are talking about the factory remote start. Any comments about low idle hurting the engine you find on the internet are just based on somebody's opinion...guarantee you there is no true data out there to support that. There is no way that a manufacturer would design or allow something to happen in the design of a new vehicle that would "hurt" the engine, and there is nothing arbitrary about any setting on a new vehicle and that includes idle speed. If there was any significant study that showed this was happening then they would program the ECM to alter the speed.
grizzstang
Calgary, Alberta Canada
You would have to tune your truck and since yours is a 2017 that would mean a programmer of some kind and a programmable PCM so it won't be cheap.
I believe they have increased the idle speed in the newer trucks and that is where that speculation has come from. I can't remember what year that started but I believe 2017 already has the higher idle.
aimvee
CA
Gas.. no.
Diesel? They will high idle on their own with factory remote start
Sent from my SM-G965W using Tapatalk
Your engine should idle at somewhere around 600 RPM, but you can't even go by that.
It is your Oil Pressure that really matters
NJMOPAR
Older and faster
ELizabeth, NJ
My 2010 high idles on remote start @ 1500rpm for about a minute, drops to 750 for another minute, then settles at 500 normal.
Of course they thought they had to 'fix' that. :rolleyes:
tron67j
Maryland
For cold starting, a block heater is arguably better for the engine than remote start. It prevents cold start, and warms the engine oil so that it flows better once you do start the engine. Used to have one on an older vehicle. While inside wasn't warm when I got in, heat was blowing very soon after leaving. If you are concerned maybe install and use that prior to remote starting. Good luck.
electricalservice
