Bloody_Knuckles
USN 81-86
Replaced recirc door and both heater blend doors. That's a job! The steering wheel, dash, and air handler box had to be removed which meant I had to evacuate the AC system and recharge. Problem now is the airbag light stays on. It wasn't on before. There is a single 4 pin connector under the steering column that doesn't appear to go to anything. Wires are white/violet, red, white/light pink, and brown (I think). I've made sure all other connections are good and I'm pretty sure I didn't miss one. Any suggestions?
P.S. Is the airbag connector part of the big clockspring connector or is it separate?
