Jared9
- Dec 30, 2015
- 6
- 0
- 2015
- Cummins 6.7
Was thinking of doing some spray on lining on rocker panels of my new mega cab and maybe the bumpers. Anyone had any luck with either
I have been told by numerous people to avoid rhino lining and get Line-X. I have also felt the two side by side and line-x seems to be a much better product.
Got pictures?I had my rockers done with line-x on my dark blue ram and I like it. Its been 3 years and still looks new, no fading at all still nice and shiny black. It wasn't the base level of line-x. No more rock chips and paint rubbing off from the factory mud flaps.
If you look at the product technical data sheets, which you can get if you ask for them, LINE-X way stronger than Rhino. For example, the tear strength of Rhino Tuff Grip and Hardline is 225 psi. The tear strength of LINE-X is 490 psi.
Do not cherry pick the data. Rhino has their "Extreme" lining that is 500-600 PSI rated.
http://rhinoapplicators.com/images/stories/Spray%20Elastomer%20-%20Polyurea/Rhino_Extreme_HP_11-50_TDS.pdf
A good Rhino application dealer is going to go over with a customer's intend use and give options tailored to that. Not every customer is hauling rock, yard or construction waste. Some commercial customers have needs for hauling product and need a liner with softer give to not damage said product with removing.
If you go into a Rhino dealer wanting the cheapest spray cost, then you will get low tear strength stuff. If you want the highest impact resistance, then you will get Extreme line.
Like I mention before, if you truly compare the same product, Rhino is competitive. Line-X does pull away though in the UV protection category.
LINE-X has Platinium which has a tear strength of 750 psi and is UV protected. There's LINE-X Pro which is also 750 psi but is not UV protected. Seems like LINE-X is a step ahead of Rhino.
I am confused, for your Special Olympic win on the internet, what are you going with? 490 or 750 PSI? Are we comparing apples to apples or apples to oranges like your first post of 490 PSI product against 225 PSI product?
