rim/tire assistance for my 04 1500 slt
67charger04ram
im looking into tires and rims to give my truck a more aggressive and off road look with out jacking it up or putting riser blocks on. i would like the tires to stick out of the fender by an inch or two and i was hoping to put 33's on. any recommendations or advice to help my search? im completely lost on this except for the fact that i like how my 20's look on the truck and would like to keep the new rims at 20 as well
m4mckeen
buy rims with a negative offset and rims that are at least 10in wide
-18 will stick out an inch our 2
-44 will stick out like 3 inches
then add some aggressive tires and that will help to stick out a little bit more because of the side wall tread.
Tyson
2004 Dodge Ram 1500 crew cab 4x4
This is how mine looks. 33x12.50r20 on 12" wide moto metals. -44 offset
m4mckeen
How far do they stick out? Got any pictures of its straight on so we can see the full effect of the offset
Sent using Tapatalk
Tyson
Sent using Tapatalk
I don't have one straight on, and unfortunately I won't be able to take one for a few days because I'm in the middle of a rebuild on my entire front end. But this is the closest I have that should give you an idea. They stick out about 2"
m4mckeen
Love that set up
Sent using Tapatalk
gjayb1987
louisiana
4.7 v8
I think im going to run the same setup. Ive got a decent price on some moto metal 20 by federal couragia 33s
LS5DodgeRam
South Florida
4.7L v8
305/55r20s is what I had on my truck stock height... -25 mm offset and they looked mean. Only problem was major rubbing on the inside of the fender. Look in my album and you can see how it looks stock height with the 305s
ChloeBrooks
