Rough country 6” lift
Gatorman1721
I’m looking at getting the rough country 6” lift for my 2019 ram 1500 classic I was wondering if there are any other parts I will need before installing the lift. This will be my first lift kit and I would hate to install it just to take it off again because I’m missing parts any advice would be greatly appreciated. I plan on getting the 6” with vertex shocks and struts and kicker bars, the kit say it had brake line brackets for the rear, so I’m wondering if I need to get new brake lines for the front and if I will need a new drive shaft.
Dean2
Near Edmonton
Do yourself a BIG favour. Buy a much better kit. Rough Country is poorly made and poorly engineered. With a 6" lift that poor design and construction is going to give you a LOT of problems.
The advice to contact Nick is spot on. He will help you get everything you need for a good job.
G
Gatorman1721
Ok what kit would you recommend I was also looking at BDS and zone. Im new to this I’ve never bought a lift kit before, so i dont really know what I’m looking for
Dean2
Near Edmonton
Call Nick and have a discussion. Buy your parts from him. The right lift is very dependant on exactly what you are going to do with the pickup when you are done. Will it be a show vehicle, or serious off road Bonnie basher, a trailer to Rock Crawl Competitions, mud drags and the whole range in between. You aren't providing anywhere near enough info for anyone to give you proper advice on here.
Nick@GotExhaust
Supporting Vendor
SC
This is great info here. Spot on.
ROUGH Country is not the way to go, they are cheaper for a reason. How you use your truck will determine what recommendations I would make. The Zone kits are very good for the money and then the shock/coil over options will vary based on how you use the truck.
Fatboy1989
