Running issues
Gapps
5.2 v8
I have a 96 ram 1500 5.2 v8 it started to idle rought , drink gas and at about 40 mph have a really horrible shake . I have a check engine light on and it says miss fire on number 2 . I replaced spark plugs , wires , distriptor cap and rotor .
Any ideas on what to check next .
HolyRamBatman
Deep in the Heart of Texas
Welcome to RF.
After changing all that stuff did you clear the code? Either with a scanner or by pulling the battery cables and see if the code comes back.
How did the rotor/ plugs look when you took them out?
G
Gapps
5.2 v8
Yeah still no change and check engine light came back , at about 40 the check engine light with flash constant
G
Gapps
5.2 v8
You could tell on the rotor it was miss firing .
Merc225hp
NA
truck
gas
A flashing cel is a sign of yes a bad missfire. Time for a comp test to be done on the whole motor. Has the plenum gasket been changed yet?
G
Gapps
5.2 v8
Not yet , to be honest I've never heard of that . We're would that be located
Merc225hp
NA
truck
gas
Ok info was posted about the plenum gasket thats good. But before you go tearing it down to fix that do the comp test first. These heads have a very bad habit of cracking between the valves.
G
Gapps
5.2 v8
Thanks to both of you , I will check that out and look into getting that changed and hooked to a computer to see what's going on .
Merc225hp
NA
truck
gas
Keep us up to date, and I hope you get it figured out without emptying your wallet.
joshhhh
