Single vs dual exhaust
kirwinjd
I Have a 2017 Ram 4x4 with the hemi engine and I noticed that some of the trucks have dual exhaust and others like mine only have single exhaust.
Anyone know the reason for that?
Thank you
yillbs
It's based on your trim level. Dual exhaust is higher trims, unless it's a diesel of.course afaik those are all single.
DILLIGAF
Canada
trim level, and both are absolute garbage regardless... just look at the Y pipe underneath. try not to throw up when you do...lol...
yillbs
Garbage? They are mathematically tuned to ensure the best possible.operatiin of emissions and quiteness. I assure you, a multi billion dollar company doesn't distribute "garbage" or non functioning emission systems. What an ignorant thing to say.
DILLIGAF
Canada
"a multi billion dollar company doesn't distribute "garbage" "
Please explain WTF this is then ? ... *****...
yillbs
Mine looks nothing like that. But even so, dual exhaust from factory is for appearance. That's not garbage, it's still functional. Though that's obviously problimatic and not intended.
DILLIGAF
Canada
So what year they did stop using these garbage Y pipes ? I must of missed it.
BAMF
Southern Louisiana
2015 Big Horn
Thank you
It's not trim level just another option me and my friend both have a 2015 big horn everything is identical except he has single exhaust I have duel.
Sent from my SM-N910V using Tapatalk
yillbs
It is trim level, but like many things based on trim is still an optional add on. Heated seats are standard on a Laramie but can be added to lower trims. Same goes with the dual, it's standard on higher trims optional on others.
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
You stopped posting for a while, I wish you would of stopped way longer.
OK.............
That does look like it would choke down 1 side of the engine pretty good.
huntergreen
didn't know this, i thought all big horns cam with dual exhaust.
huntergreen
my observation is the dual exhaust also sound different/better than the single, so its not just for looks.
Farmer Fran
Earth
2020 Limited Loaded - Sold
So how much HP/TQ does adding a "proper" H or Y pipe add?
huntergreen
the y-pipe is often one of the first mod replacements we do.
DILLIGAF
Canada
I dunno, I got LT headers, Tuner and replaced the entire garbage factory setup all at once :crazy:
Its pointless to replace the factory Y pipe if you keep those ridiculously restrictive factory manifolds.
Maybe get under your truck and look before you flap your lips mouthpiece,every Y pipe on a 4th Gen look's like that *******.
I'm with the other guys,sure enjoyed it when you weren't posting,can you go away again,and make it longer this time,maybe like forever,lol
Another dumb answer,you better go look at the higher level Eco Diesals,they come with dual exhaust these days too.
Dmopar74
Are you kidding me? They all look like that, even my 2016 6.4
