Snow chains for a 2010 1500
jon0m0berry
So owners manual says no chains/cables at all. I know the front has suspension parts in the way, so thats a no go. Ive looked up else where as to why you cant instal them on the rear, and people are saying the brake line is to close if I remember right. Has anyone found a work around? I would only assume a brake line could be moved out of the way. Im not familiar with brake systems. But has anyone looked into this? Is there anything that can be done to safely put chains or cables on the rear wheels?
Brandon-w
Yukon
2015 Ram 1500
I use them on my 2015 ram with no problems. They just rub the plastic inner liner a bit which doesn't matter to me.
Random_Walk
...what's this bolt do? *plink* ...oh.
Out
2017 QC 4WD SLT
Pentastar 3.6
I have a set for the rear wheels of my 2017, but eTrailer.com specifically found a set compatible with make/model/year... and the test fitting worked just fine, with nothing in the way.
