well if they would take it out of park it might come out.I will NEVER pull a car out, sorry but with my luck
You picked up what looks to be a very nice strap. This strap looks to be able to handle "snap - pulls" in which you get a small rolling start and allow the strap to stretch and give extra force by jerking the stuck vehicle slightly to "break" the static tension / adhesion of being stuck. Just make sure that all attachment points are strong and secure. The shackle receive you purchased will serve you well, but also know that a strap loop shoved in the receiver box and a hitch pin slide thru it is also a very secure attachment point.
The last piece of advice I'd give is particularly when pulling out cars as you have a substantial weight over them is to have the driver place the car in neutral and key their foot on the brake. You do not want them stopping on the gas, catching traction and launching in to you, particularly if you are pulling them back on to an active roadway in which you may have to stop pulling to avoid another car on the road.
The other advantage to brakes on in the car being pulled is if necessary you can strap thru the rim to pull on most cars with alloy rims, vs steel wheels. Not the preferred choice but it does work and is a low risk for damage to the car being pulled.
So the wife has a 07 Forester and I got her the new Falken Wildpeak AT tires for the snow here and works great but still you never know.
I bought a recovery strap of 22% elasticity and got myself a shackle hitch.
Do I need anything else and do I need to worry about hurting my truck by pulling someone out of a ditch?
