So what about pebbles in the tread?
Burla
2010 Hemi Reg Cab 4x4
My RAM lives on gravel over a decade, when you get off the gravel and onto the pavement the bad ones will let you know with that sound. Only those audible ones do I bother to remove. Not all gravel is equal as well, if you drive on 3/4 inch I wouldnt want that stuff in my tires. I'd check every week or so if that is what you are on.
rvance
Pent 3.6
Really!? You guys are worried about pebbles in the tread? We've lived in a rural area for over 20 years and I have always had A/T tires of one brand or another.
They always pick up small rocks and pebbles, there is no avoiding it. The tires have NEVER suffered any ill-effects from it.
Here is a set of Cooper A/T's with over 50k miles, when they were newer they picked a lot of rocks. Never had a problem.
You guys are worrying about nothing.
I have Cooper Discoverer ATs on the rear and Cooper highway tread on the front an I park on pea gravel and drive over SB2 every day and I have never had any concerns about it sticking in my tires. Not a real world problem.
O, there was hyperspeed after dropping down a couple of gears on the ZF and planting the skinny pedal.
In all honesty, I may have missed checking for the tread Klingons during my post-launch inspection. :cool:
A hell'va sized burn-out usually eliminates them from the rear tires,then a couple hard and fast twitches of the steering wheel at 50+ mph will usually work most of them out of the front tires :Big Laugh:
RamDiver
Marlborough, Ontario Canada
2021 DS
I've graduated to using the Pedal Commander in the Sport settings as a SOP, but managing to keep the wheel-spin to a minimum. :cool:
I haven't paid much attention to the tire Klingons yet this season, although I only installed the summer wheels last week.
The Michelin Defenders regularly collect Klingons.
Jeepwalker
WI
2012 Reg Cab, 4x4
When I rotate my tires (I do them myself), I inspect carefully for deep imbedded rocks and/or glass. Or other debris. Sometimes there can be a sharp rock, sheet metal screw ...or other, which gets into a sipe or works into the tread with the sharp end 'in'. Such objects can continue to work in deeper over time. I have in the past found pointed objects that I've removed (I have other vehicles too). I extract any suspicious ones with a curved pick tool. Doesn't take more than a few minutes per tire.
Small round rocks between tread blocks I'm not concerned with. It's the small sharp ones pointing in that worry me.
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
Must be an American thing… we have gravel covering the roads 7 months of the year… a typical Alberta windshield has on average one crack and twelve rock chips.
We still have gravel all over the roads in May. Unless you have a dually slinging baseball sized rocks, you’re fine.
Canadian winter,amiright? if I stopped to pick rocks out of my tires,I'd never get anywhere,and spring in B.C means new windshield time.
Steve Holtz
