Solid Axle Swap? Done Before?
Jeepwalker
WI
2012 Reg Cab, 4x4
It would be fun to do. I haven't personally seen a detailed account, but hopefully someone will post one.
An owner would probably be far better off just buying a 3/4 ton tk bc it would save a ton of work/time and get it right the first time w/o years of costly headaches to iron out. And with the 2500 you get all the other HD gear and lose some electronic nonsense (on the new tks), even though it would be more up front $$. But at least the engineering would be 'right'.
But then again, with a Ram there's a body of parts (axles/steering/suspension) from older rams and 2500's to tap into or adapt which should (hopefully) reduce engineering and guesswork that other SAS guys face. A lot of SAS swaps on Toyotas, Hummers, etc I've read on 4x4 forums ...honest owners quite often say they never got their swaps to handle very well on the road (off road they're great), and many end up selling and going to 3/4 ton rigs anyway (and advising owners to consider living with the IFS limitations).
Sorry this post isn't very helpful ...probably stuff you already know.
I was quoted 3500 for this from local shop, we didnt get into details on what to do with the block in the front, either use it if I went up high, or cut it off. It is a bummer trucks don't have a SA as an option anymore. There are some examples of light SA's in the market place that are working, Wranglers for one, some foreign 4x4 we cant get here. If you ask me being what it is, mise well go up to a 2500 and get a SA standard. I think most guys would prefer it and yet we cant get it, just another example of the market place not ruling the supply/demand issues.
Cost of the axle and labor side 3500, it literally would cost the same to move to a 2500, but you get a lot more for the 6 grand then just an axle. But yeah if there are some guys with the know how and spare parts, it would be nice to see if ram forum has an example of this...
DILLIGAF
Canada
One guy did it on the other forum a while back. his verdict ; Its cheaper to buy a 2500.
22hemi13
Tucson AZ
2014 2500 4x4
Buy a cheap used gasser 2500 and go to town. You get the heavy duty frame. All the right components are there and you’ll end up cheaper in the long run for a truck that works right. Mine was a long bed. I’d go 6’4” bed route and keep it looking like a truck. But mines a toy
nice truck man
Sasquatchtdg
Sasquatchtdg
Moncks Corner, SC
I see it done a lot with the Chevy's, half the time just to get more lift for YEE YEE purposes, not legitimate off road capability. I'd bet that 75% never have the front drive shaft installed. It sucks that they did truck guys dirty with their almighty wisdom behind making a front diff that you can't change ratios without a unit swap in the 1500s. Just a bored at work thought.
Orca
