Sorry, Windshield wiper not working.
2tast4u
huntsville
I have had so many problems with this thing. First the intermitting wipers would work when they wanted to then sometimes they would just start running when off. I fixed that by replacing the motor. Then when ice came I cranked the truck, didnt remember having them on and they moved till they hit the ice and died so I bought another motor and it only runs on high and will not park. I've swapped relays checked fuses, checked power at the connector. I got 12v at two pins in low mode and high and even gor intermitting power on the other wire. One has low voltage, not sure what that is.
2tast4u
huntsville
I swapped that motor out for another now and it only runs on high as well. What am I missing?
aviatorblackout
NC
By process of elimination I would have to guess its the multifunction switch too.
You can clean them, worth a shot if you have the tools, you will need long small torx:
Or buy a new one
Smokeybear01
US-NW Coast
Cummins 5.9
Do the contacts on the back of the motor come with new motors? If not, clean them up good with some sandpaper and then dialectric grease. Good luck,
MK82
Houston, Texas
5.9 HO Cummins
I vote multi function switch too. My 05 Daytona had similar issues with the wipers, went through 2 motors before i realized it was the switch. I didn't know you could clean them so I just replaced mine. Good luck bud
Matt
SYKRAMMAN
Banned
Jersey shore
06 Mega
It's most likely the multi switch, make sure to use oem, aftermarket is junk, same for the motors. Ask how I know:(
