spotty/no accelleration and occasional "lightning bolt" on dash???
goldlifter
Hello, new around here and new to Dodge gassers.....I have a 2004 5.7 with high miles that everything works great EXCEPT acceleration. When i floor it, i get a "dead pedal" where it cuts out bad and once, it went into "limp mode" and could hardly turn the truck. Usually when i floor it, it will bog down then it will rev up and really haul ***. Another time i was driving on the interstate with cruise control on and the truck cuts out and I get a "lightning bolt" on the dash. I pulled over,restarted and it ran fine. I have yet to get any kind of "check engine" code.....any thoughts? Any help/info is greatly appreciated
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Welcome to RF bud. Only other thing to check on is if the TB was recentrly cleaned inncorrectly and it damaged the electronics.
G
goldlifter
truckin151
2013 sport
I have to ask. You haven't gotten any check engine codes meaning lights not on, or you have checked for codes via tuner or key trick?
Also does it stay in cruise when you hit the button or does it not engage cruise control at all?
G
goldlifter
No engine codes at all as of yet....i'll try my OBDII scanner and see if it pulls anything but without a "check engine" light, i don't think mine will be of any help. I wish it DID show a code so I could narrow it down better
It stays in cruise control 99% of the time. It was just that instance last week that the lightning bolt came on the dash(blinking) and it kicked it out of cruise control
truckin151
2013 sport
Alright, definitely check with the scanner. There are codes that won't trip the check engine light. I have had a few that have popped up when mine wasn't acting right that never threw a cell.
G
goldlifter
You were right, the stored code was p1349....does that narrow it down any?
antony rudd
england
hi
had the same problem on my 04 hemi Tried a new throttle body and new electric throttle control none worked .Ended up cleaning the original throttle body all the crud from the engine so it it was clean used electricial contact cleaner worked ok ever since the deposit build up on the throttle assemby had obviusly affected the weight of the throttle flap causing the truck to go into limp mode funny how none of the new stuff made any difference unless it was faulty
New Rhino
