Steering Wheel Extender 2021 Ram 2500 Power Wagon
CWin
Hemi 6.4L
Is there a way to extend the steering wheel by about 2 inches? If I back the seat up enough to clear my knees, I can't comfortably reach the steering wheel without sitting completely upright, almost pitched forward.
Fast69Mopar
The only way I have been able to do this is by using a steering wheel spacer. Remove the steering wheel and measure the diameter of the steering shaft in the column and measure the diameter of the clockspring. With this info you should be able to find a spacer that will work for you. I normally have to machine mine out of 6061 aluminum
