Stereo Clarification
KWG88ss
Pennsylvania
Can someone can please answer this:
I have a 2018 Big Horn, non alpine, 8.4 screen.
I have 2 door speakers front and back, and three in the dash.
Yes, three. I have a center dash speaker.
I’ve been told I should not have this third speaker by a few people. Before I spend anymore fixing my setup can people confirm whether I should be targeting 2ohm or 4ohm speakers for the front.
Thanks.
heefageLA
Vidalia, LA
05, 14, 17, 20, 23
If worse came to worst you could pull a speaker out and check the resistance with a volt meter...
rsdata
N Ky
2014 BigHorn 1500 8spd 4X4
a voltmeter will not measure resistance ( 2 , 4 or 8 ohms) accurately of a voice coil of wire in a speaker... the resistance in a speaker is really impedence measured in ohms... the resistance in a coil to an AC signal...
Read more here... https://www.wikihow.com/Measure-Speaker-Impedance
buddy guy
alberta
btw, have you looked at your build sheet to see what it says about your stereo? i'd be curious. i know you said its not Alpine but i'm not famiiar of our trucks with a stock center that is non Alipine system.
stimpy433
IOWA
Have you actually seen the center speaker, cuz my truck has a center speaker grill but there isn’t a speaker underneath it....
buddy guy
alberta
yeah, that's what i was wondering. mine too. just a stock dash option they put in I think.
K
KWG88ss
Pennsylvania
When I get home I’ll rip off the cover but when I had the amp installed the shop was confused because the wiring sheets said I shouldn’t have had one.
K
KWG88ss
Pennsylvania
Ok, thankfully I don’t have some bastardized RAM that rolled off the assembly line with jacked up electronics. I guess installer assumed there was a speaker under the cover.
So,
With the 6 speaker setup: will this amp:
https://www.sonicelectronix.com/item_94448_Soundstream-ST4.1000DB.html
Work with the Infinity Reference 3.5’s as well as the Infinity Reference 2 way 6x9’s?
Michael
In an undisclosed bunker
The oem dash speakers are 8 ohm.
I know the voices in my head aren’t real, but man, do they ever come up with some great ideas
TomT
SoCal/OC
K
KWG88ss
Pennsylvania
It’s a 4 channel amp, how were you planning to wire the six speakers? Does that amp take high level inputs? If not, you’ll need a LOC at minimum.
What’s your final goal for the system?
I’m only looking to push the front 4 probably.
I’m going to pay a local shop for the install of amp and anything else it needs.
Final goal would be to sound better than if I paid for the alpine but not expecting to win any competitions.
TomT
SoCal/OC
Will you be adding a sub as well? If not now, then down the line at some point?
K
KWG88ss
Pennsylvania
Yeah down the line I could see myself putting in rear door speakers being powered as well as an under seat sub.
TomT
SoCal/OC
Then your best bet is a six channel amp with some processing built-in. That way you can power the 4 doors and dash with a single amp. You’ll want the processing so that you can adjust the dash volume independently. If you don’t, the dash speakers will overpower the doors and you won’t get much midbass.
This amp looks pretty cool. You get 45w for the dash and rear doors plus 90w for the front doors.
https://www.sonicelectronix.com/item_151809_Sony-XM-GS6DSP.html
K
KWG88ss
Pennsylvania
What would you recommend for rear doors? Ideally I would like to stick with JBL/Infinity for the front but not sure if:
A. 45 will be able to power much
B. If I need anything fancy for rear doors
Where are people hiding these bigger amps anyway?
TomT
SoCal/OC
You can use the same 6x9s that you use in the front doors. Normally you don’t play the rears as loud as the fronts. There are much higher power six channels but you will pay a lot more for them.
For example: https://www.sonicelectronix.com/ite...html?refSrc=lc61200&nosto=productpage-nosto-1
That’s a great amp with a full featured DSP built in. The price reflects the quality though.
As for where to mount them, I like the back wall.
TomT
SoCal/OC
If you already know of a good shop, find out what brands they carry.
K
KWG88ss
Pennsylvania
So, took a longer drive to a pretty well known place.
Rockford DSR1
KFC-XP6903C
KFC-X694
Sony XM-GS4
Full install, wiring, etc, etc
$1197.
Thoughts on their proposed setup? Price seems more than reasonable when I google all the items.
