Stuck rear fuel filter by tank
DASasphalt
North Carolina
Have a 2018 Ram 2500 for about a year and attempting to change fuel filters myself. Front wasn't a problem but can not get the rear off. I've tried everything from chain wreck to a screw drive and a comealong. Broke the screw driver before it popped loose. Any ideas on tools to use and tips to get it off?20220929_183501.jpg
Wallyb4
Retired EWC(SW/AW) 1983-2003
Virginia Beach
5.7L
Have you tried spraying some penetrating oil in the top of it and let it soak in for a few minutes?
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
Administrator
If the filter housing is that hard to remove, cut your loses and replace the whole thing. Good possibly it may not seal up with a new filter assembly.
D
DASasphalt
North Carolina
Couldn't get under the truck yesterday cause of the storm but I plan to drop the drive axle to have better access. If I can't get it off them, I'm taking off the whole assembly. This is ridiculous, I have all kinds of equipment and the newest truck I have is the hardest. 10 min job taking 2 days.
OLEJOE
N. La
6.7 CTD
Get a web strap wrench that goes on a 1/2” ratchet and use an extension long enough to reach from under the drive shaft. That’s what I used on mine.
PS; make sure you are turning in the right direction.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
I just did mine yesterday. I use a metal oil filter strap wrench. Bring the new Mopar filter to the store and match up a good fit. I use the driveshaft against my arms for leverage. The last guy obviously overtightened it. They don't have to be that tight and I never had one leak. You'll get it.
easymoney951
Socal
Have a 2018 Ram 2500 for about a year and attempting to change fuel filters myself. Front wasn't a problem but can not get the rear off. I've tried everything from chain wreck to a screw drive and a comealong. Broke the screw driver before it popped loose. Any ideas on tools to use and tips to get it off?View attachment 503265
Mine was stuck badly I used a pipe wrench and bar from jack for leverage worked like a charm
Choupique
Louisiana
Cummins
Big ass pipe wrench, metal strap wrench, big ass channel locks, etc.
chopperdog45
GA
CTD 6.7
Sooooo.....
Did we ever find out if this was resolved? The suspense is killing me over here!
Orca
