Stupid questions, Terra Grappler G2
Niteboss
Is there an inside or outside sidewall? Asking because each one has a different pattern.
Also what psi do you guys yours at?
Thank you in advance
BOWERSFJ
Uniontown OH
Yes ... 2 different sidewalls to choose from ... It shows you both on Nitto’s website ... And if you don’t remind the installer, you get 2 and 2 like they did my Toyos ... PSI depends on what you’re runnin, and what you’re doin ... P LT 10 Ply Towing ... Just depends ... Probably not many runnin their 10 plys at 80 PSI
N
Niteboss
They are just stock size 275/60/20. Tire says 50 max psi
TatertotScott
The man, the myth, the legend, the one and only!
La Center/Amboy, WA
Then run factory +/- a few for comfort.
Common sense isn't...nor is common decency.
Cshaffer126
Virgnia
I bought mine from custom offsets, they come standard with the more aggressive sidewall mounted outside. I run mine at 60 PSI. But i'll be honest i'm not really sure what they should be. I have 35/12.5 LT E
PerfectCreature
Maine
I just purchased the G2s myself after having the Cooper AT3 LT tires. I decided against a 10ply and went with the regular. I will be going with the space ship style outside and the bolts on the inside. Ill probably run mine at 35-38psi out of the max 44psi.
Gary2
S Jersey
I will also be going with the G2's to get away from E rated 10plys and lose about 20lbs of unsprung weight per tire.
PerfectCreature
Maine
Exactly, the Coopers are 52.4lbs and the G2s were like 46lbs or something like that. That weight is going to make a difference. I went from 18mpg with the factory SRA to 14.6 with the Coopers. Hoping to meet somewhere in the middle.
