Sunroof leaking by the grab handles
Runaround
Silsbee
I have an ‘07 model and the last time it rained I had water coming out at the A pillar grab handles. I have once before cut a little bit of the rubber piece by the hinge. I even squeezed them some this time and got some water out. My question is what do you use to keep these lines cleaned out and where is the upper end of these drain tubes located?
HemiLonestar
MD
LP air tuned waayyyyy down so you don't blow the tubes off. The trick is getting to the drains, they should be a ways back.
dustinb80
Ohio
Had the same issue in my 2500. Took it to a dealer, they said it was the drain tubes clogged from production. They cleared it out, but happened again months later.
Runaround
Runaround
Silsbee
So you are saying these tubes are on the sides? I assumed they were somewhere near the front.
HemiLonestar
MD
Godd@mn, 4 of them lol.
turkeybird56
Central Texas
EXACTLY why I would not buy a truck with a Sun/Moon roof ne thing.
Wallyb4
Retired EWC(SW/AW) 1983-2003
Virginia Beach
5.7L
The drain tubes will drain out in the fender wells. Look for some tubes in there. Use a can of compressed air and find the drain tubes located in each corner of your sunroof. Make this a quarterly event.
