Tail Lights 2021 Ram Not Working
the real cpt kirk
North Carolina
5.8L Hemi
Hey all, I have a 2021 Ram and tail lights notworking, brake lights and signal are working properly. Checked and replaced fuse F11 under hood but still zero luck. any help would be greatly appreciated
Htmsr24
Did you change the tail bulbs. 9/10 this is the problem with these trucks if all other lights work. They burn out/short very easily and are poorly sealed in the assembly and yes both can go out at once. I've had it happen on 2 late model 1500's. 7443 LL from WM $6.
Dean2
Near Edmonton
LED? or standard bulbs. Assuming Standard, change the bulbs. Believe they are a 7440, not the 7443 from above which should be the front turn signal bulbs. If they are LED you have more diagnostic work to do. First step, make sure there is power, quite common for there to be a break in the wires from gravel damage or a bad bend in the wiring.
turkeybird56
Central Texas
Brake but not tail/running lights. Gotta be fuse/wire short? Not think it be canbus.
