Tank won't take any fuel
gunnersmate
Louisiana
Someone put 28 plus gals of gas in my 2500 6.7. I used the lift pump and fuse number 70 to drain the tank at the drain hose on the front fuel filter. It worked like a champ. I went to fill my tank with diesel to finish a complete purge, and now my tank will not take any diesel at all. what happened?
There should be a rollover valve at the inlet of the tank, unfortunately it's part of the fuel tank itself. Try pulling the filler neck, if not since the tank is empty just drop the whole thing.
Glowz
