Tappet Cover Gasket
eastbayboy
Cummins diesal 24 valve
I have a 2001 Dodge RAM with a Cummins 5.9L 24V truck. I am in the process of replacing the tappet cover gasket due to an oil leak. I bought a new gasket and am trying to make sure I place it on the cover correctly. The gasket has a grove which fits over the edge of the tappet cover. My question is one side on the gasket is at least twice as thick as the other side (see pic). Which side goes against the block??
Also there is a tab on the gasket which has "front" written on it and is on the thin side of the gasket. I assume the tab means that it goes to the front of the engine.
Advice would be much appreciate!!!
Eastbayboy
goodtodoo
1996 indy pace truck
Put it on the way it came off. I haven,t done it, but I would think the thick side goes down. Sorry I can,t be of more help.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Make sure the gasket is properly located around the cylinder head bolts, with the words “top front” facing up and towards front of engine.
RoadBully
Compression Ignition
It's a Cummins not a Magnum, this gasket is on the drivers side of the block. Fat side in, front towards front of block.
dudeman2009
Magnum 360
Thats directly copied from the factory service manual from the Cummins section.
Steve58
