ArcherOfStardust
Ok guys, any help would be greatly appreciated. I have a 2006 Dodge Ram Mega Cab 5.7L Hemi. I love my truck, I've had it for 6 years but man lately, it seems like I can't get it! Truck started over heating, maybe like a month ago, off and on. Took more antifreeze than usual. Eventually it over heated and wouldn't start. I had to have it towed home. When I got home and checked it out, the water pump was cracked, everything was just leaking out immediately. Replaced the water pump. It seems good for a few days but temp gauge kept fluctuating from cool to hot, back and forth, wouldn't stay at one level. So a couple days after water pump was changed my truck over heated pretty badly, smoke and everything. Pulled over immediately. Once it cooled, popped the hood, temp fix out some water in it to get to the mechanic down the street. Come to find out radiator had a crack in it.
So more work, more money into my truck. Radiator, hose and thermostat was all replaced (radiator cap was replaced when water pump was). Truck seemed okay for a day before anything wonky. I've driven it to work the last to days, drive is about 40 mins each way. Gauge started fluctuating again, it goes to hot then back down to cool, then maintains in the middle then goes up hot where the check gauges light will pop on because the truck is reading as it's really hot. Then that will go back down. Sometimes it will seem like it's getting a little warm maybe but most of the time it when I've driven it the last couple days, it doesn't seem like it's getting hot to the point of over heating but I'm sure whatever is happening can't be good for my truck. Has anyone ever experienced this or know what is causing this?
