Lilhoss77
So over a month ago I was sitting in my 2017 1500 5.7 hemi Bighorn late one night or early one morning smoking a cigarette. Something I don't do in the house. Normally don't sit in driveway to do it either in truck but it gets hot in L.A. Lower Alabama so come daylight I was woke up key on truck not running. I thought I am a idiot. I must have fell asleep and ran out of gas in my driveway. Yes dumb I know. I put a 2gal and 5gal gas can in another vehicle to get gas. Once put in my truck 7gals or there about I noticed it registered about 1/2 tank. 26 gal tank 7gals is not 1/2 I am pretty sure. Short story long I had to charge battery and did. The truck tried cranking but no start. I do and have had Trinity platinum 2 EX for a while. And I have other scanners as well. No start ever and now no crank from turning ignition. I have since purchased Alphaobd and tried reading codes as I figured it was more expensive than my cheap scanners. I was getting service transmission, the rotary shifter did have PRND all lit up in yellow and that was on dash instrument cluster in all yellow too. I have since installed new battery. Cleaned all the negative cables I could find. And now the cluster doesn't show the PRND at all but I keep getting no communication with TCM and alot of the Modules are saying if I enter vin failure outside of parameter. Any one that has ever seen this or like this any help greatly appreciated. If I hook Trinity to truck it says last attempt at programming failed which is weird it was programmed before this happened??
