Thoughts on this intake from Jegs?
AWE Daniel
Banned
Can't be much worse/better than the pvc stuff
ramhunter9
P-Star Jeep Wrangler
make your own and get a drop in K&n filter . we all do and it is just the same function as that .
Seems a little high priced. Why not just buy an eBay one or make your own? Basically the same thing but won't cost you as much. Just a thought.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
screw all that, get a Vararam! :D
I had 3 intakes on my 08, an Airaid, BFI and Vararam. The Vararam kicked butt!
ramhunter9
we need numbers to prove witch is better JJ . all the same . FUKKEN TUBE AND A FILTER .
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
numbers on a dyno aren't going to do much good. Especially with the vararam, as it forces air through the tubes as you move.
You guys can say its all the same.......but its not. :D Or my butt dyno needs calibrated. But......this is performance ****, I don't care about that. Run whatever the hells you want! :D
dterrel
