Timbren DR1500DQ
Status
Not open for further replies.
stateofdade
Trenton, GA
Cummins 6.7
https://timbren.com/blog/products-page/dr1500dq/
These fit 4th gen 1500's. They literally replace the stock bump-stops. I've used them for about 7 months and upgraded to a new airbag system. I hauled a TT and these completely eliminated any and all squat while firming up the ride and eliminating sway. Great if you're on a budget. I paid about $215 for them. Will let them go for $160 shipped. A bargain if you consider that the minimum shipping fee is over 11 dollars at their current weight. I work for the USPS so I can literally mail them on any day but Sunday.
I've also added the 1 inch spacer to increase height on these. If you have the factory lift, they're right on the money. If you don't have the factory lift, simply remove the spacers and get a shorter screw set at your local hardware store. At most, you'll have 3-4 extra dollars in hardware involved.
Dr B
Hollister
Do you still have these? Interested in buying if they fit a 2016 1500 with factory lift.
Charles
Status
Kmiko
