TIPM problems
DustyB
Oregon
wore out a 98' and 07' and working on a 2013
diesel
TIPM problems seem to plague the 4th gen trucks... I see the recall for durangos an few others ... not happy dropping 600$ for a pos box exposed to the elements... I had wiper issues and traced it to the tipm dealer said they did 5 tipms in the last 2 months. Pluss they charged 120$ to flash it to my vin# it came with all the relays and fuses installed so now I have plenty of extras :flipthebird: what ever....
2013 3500 Laramie 6.7
deleted 70,000 miles
R.L.K.
Bristol , Tn.
Damn ! So I'm assuming the TIPM doesn't have a replaceable relay for the wiper controls ? That sucks ...
D
DustyB
Oregon
diesel
Nope... Much of the brains, relays and modules are internal, they corrode and become problematic.
Hemi395
Cape Cod MA
Damn that sucks. I was hoping all the TIPM problems I've been reading about weren't affecting the 13+ trucks...
kscull70
Northwest PA
2009 Ram 1500 Laramie
Just had a new one put in my 09 today as well.....
Kapt
3L
What exactly does TIPM stand for?
Hemi395
Cape Cod MA
Totally Integrated Power Module
The main fuse and relay box essentially but half the relays are soldered onto the circuit board and can't be replaced necessitating the replacement of the whole TIPM
FireChief
Northern NY
Cummins
So I have had dead batteries every morning for over a month, unless I pull the fuse for the wireless ignition module. Dealer has replaced module along with wireless hub. Issue persists. Now they are thinking TIPM, however the TIPM for my 2013 Ram 2500 diesel is backordered. Not sure if this will fix the issue, almost feels like they are grasping at straws. The vehicle also does other odd things such as the windshield wipers coming on and off on their own, and the exhaust brake turning off and on also on its own. Like a ghost in the machine. Anyone have any ideas what the lead time is currently for the TIPM on backorder? Thinking maybe a new truck would be faster and more reliable.
SYKRAMMAN
Banned
Jersey shore
06 Mega
WTF! I can’t believe they STILL haven’t fixed this tipcm problem! What a joke of a company. They don’t even make them anymore for my old truck, I have to take chances on junkyard boxes and waste a hundred bucks to have it flashed each time and that’s not including my time or parts!!! This just boggles me, such a huge company and they can’t figure out how to stop this issue. I guess all car companies have their issues huh! Why can’t they move these such important parts to a more suitable location so they are not susceptible to the weather? Just amazes me, sorry for the rant but I just know it will keep happening and there’s nothing we can do!
Mikro
Dallas TX
My TIPM caused my battery to die on my 2011 or not start but turn over fine getting no fuel. The fuel pump relay went bad on it. Sometimes stay open (no fuel) or sometimes closed ( dead battery) I used these guys to repair it ( see link below). Took about 7 days total shipped both ways and less than $350. I did not have to have it flashed as it was the one that came out of my truck. Also came with a report of all testing before and after.
http://verticalvisions.com/
MK
Hemi395
Cape Cod MA
My TPIM caused my battery to die on my 2011 or not start but turn over fine getting no fuel. The fuel pump relay went bad on it. Sometimes stay open (no fuel) or sometimes closed ( dead battery) I used these guys to repair it ( see link below). Took about 7 days total shipped both ways and less than $350. I did not have to have it flashed as it was the one that came out of my truck. Also came with a report of all testing before and after.
MK
That's great so they changed the fuel pump relay for you? From what I understand it's the relays that are soldered to the main board that cause the TIPM problems...
2010 Infantry Vet
Butler pennsylvania
My wipers wont turn off, all dash lights are on, gauges dont work, window buttons dont work, and headlights stay on when turned off. Does a new tipm fix all of these symptoms?
Mikro
Dallas TX
Yes they did and tested all circuits. If they find anything else wrong they will contact you and give you the updated cost if any. I was and am very pleased. He usually has a 24 hour turn around once he receives it. He has a lot of good info on the site to explain the process and problems.
edited to add: I see they finally have their plug and play fuel pump relay kit now. :)
FireChief
Northern NY
Cummins
The more I hear about these TIPM horror stories, the more I want to just get a new truck.
Brander
Can anyone with a prom unit flash these or does it have to go to the dealer? Do the aftermarket ones work or have the same problem?anyone have a schematic for the board so you know what is what once you have it opened up? I have been soldering for 40 years im sure I can handle it, may be able to see the problem child as well but if there is a "MAP" that saves diagnostic time:) I have cruise, 4X4, and rear slider window not working and was told TPIM is the problem.
Thanks for any help and info for this
Hemi395
Cape Cod MA
I don't believe there is an aftermarket option for the TIPM. From what I understand the TIPM itself doesn't normally go bad, it's the internal relays that go bad. The horn, wipers, and fuel pump are a few I know of.
You can buy the relays for under $10 so if you're good at soldering you should be able to fix your TIPM pretty easily.
Really stupid design. An $8 relay causes people to pay $600+ to fix.
Programming the TIPM I believe can be done with a highlevel scan tool such as the Autel but I'm not positive on that...
Brander
RockAuto has a couple of options, Dorman and A1-Cardone advertised as remans, and they charge a core if you do not send yours back. I am assuming they are resoldering any bad connections and shipping them out, which is why I was wondering about the prom flash
