Tire confusion????
jeffawats
thompsontown pa
I have looked at many posts and I havent found a real clear answer.I want to run a 305/50/20 on OEM polished sport wheels I have 1.5" wheel spacers and am leveled with rear lowering springs 18 QC 4wd. I am also adding OEM fender flares does anybody run this setup or able to direct me to the proper resources for an answer.If I order the tires and mount one up to test fit I wont be able to return it.
MAJ_Charlie
VA and NC
I currently have 305/55/20s on mine with Bushwacker OEM type fender flares and aftermarket 20x9 wheels. Mine have a +18 offset and it fits perfect without spacers.b588e8b42dff0b7351646b0968116d9a.jpgaa3a5b5dbbfbbe8037c2cdb11bf0dd2b.jpg
MAJ_Charlie
VA and NC
looks great thanks MAJ_Charlie
Thanks. Still working on more mods :)
Not sure about running 305/50s though. You'll loose 1" in tire height from stock size (275/60/20) whereas running 305/55s will put you .2" over stock tire height. Hope this helps.
jeffawats
jeffawats
thompsontown pa
Not sure about running 305/50s though. You'll loose 1" in tire height from stock size (275/60/20) whereas running 305/55s will put you .2" over stock tire height. Hope this helps.[/ The problem is I wanted more of a sport/street style tire and the 305/55s are mainly M/T and A/T tires which left me with going to a shorter tire to get what I'm looking for.
jeffawats
jeffawats
thompsontown pa
ordered a set of 305/50's yesterday. will test fit one tire with a blanket underneath to check clearance.Just in case I have to return them
jeffawats
jeffawats
thompsontown pa
my 305/50's showed up yesterday ,can't wait to get one test fit hopefully all clears well they are wide as hell compared to the stockers
ThunderMug95
North Prince George, VA
4D2D7405-7099-41FC-B8C8-5EA0FB164EB9.jpeg They are very wide. I found my rub, not on plastic. I make slight contact with my track bar at full lock. My sidewalls have aggressive lugs, so not worried.
And before anyone makes a comment about the CV angle...the truck is on jackstands, suspension at full droop.
KAKA
