Tire Pressure
smokedbystang
Central Florida
2012 Ram 1500 Express 4x4
Not sure if there is a tire pressure thread. It won't let me search on my phone.
I just got a set of 275/65r20 (34") Trail Grapplers. The shop put in 35psi. Just checking to see what everyone else runs in 33-35" mud or off road tires on the street. I just want to make sure they wear even. I plan to rotate them every 3k miles too. Thanks.
gmbohuntr
I run 60 psi in my 35" M/T's...
Sent from my SAMSUNG-SM-G920AZ using Tapatalk
gmbohuntr
I'd follow what the sidewall says...alot will depend on weight rating as well...
DannyMK2
Long Island, NY
2015 Power Wagon
thats actually what your not supposed to do.
35 might be OK. im sure tire shop did that because thats what your truck calls for and its a good starting point. being that your now running e-rated tires, you may be better off with a few more lbs of pressure. i'd probably guess around 40psi. best way to check is to chalk test your tires. if you have even contact across the tread your fine.
BCA87
Central PA
I run 285/65/20 Terra Grappler G2's..Shop filled them to about 37 PSI and after chalk testing I settled at 42 PSI
gmbohuntr
I don't know that I'd run e rated tires that low. A lot of stress on the sidewalls. If I go much below 55 psi my truck tracks like crap and the ride goes to hell. I've always been told, and always have, ran E rated close to recommended pressure. And have gotten excellent mileage out of them. Stock tires, follow the door placard.
gmbohuntr
I'm also a 2500, so there's a difference there as well...
blackbeautyhemi
Lewistown, PA
Yea 60 is okay in your case but a 1500 you're good at 35-40 to wear even. Put in higher then you'll be rounding the treads and wearing the middle out faster. These tires have strong sidewalls so you can run a lower tire pressure.
gmbohuntr
Yeah, didn't realize he was talking about a half-ton til I saw his sig...
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
For what it's worth Discount Tire set my pressure at 45 for my Nitto Terra Grappler G2s 35x12.5r20 E rated.
quietpeen
2021 TRX
Hellcat
I run whatever pressure it takes to give an even contact patch
Steveo8x8
So Cal
2017 Ram 2500 Megacab
6.7l Cummins
On my 1500 I did 42 front and 38 rear with my mud terrains. Sold the truck at 35k miles and still had about half tread left.
Steveo8x8
So Cal
6.7l Cummins
I always bumped the rears up to 50 when towing my trailer
KAKA
