Tire Rotation Question
Davidloveshishemi
Tn
2019 Ram 1500 Classic
5.7 L Hemi
Thinking about doing my own rotations, but I was curious about whether the truck registers where the tire are in relation to the truck. Or if you need to have them rotated at the dealership to have that set? You know RF, LF, RR, LR. So that is your display everything is in the right spot.
Just curious.
Thank You!
Princeton_Man
Princeton, WV
The truck automatically figures it out, so you don't have to do anything extra.
Has that always been true or just for later models? My tire shop labeled my Winter tires for location and suggested I do the same for my Summer tires when I swap them this Fall. The shop said they have to program them for location. After I drove off, I got to thinking what a PITA it will be to rotate my tires and have to take them back to have the TPMS sensors reprogrammed.
Neil E
Morganton, NC 28655
some vehicles are different than others. Some require you to do a "reset". I did with my old Chevrolet (2016)
stimpy433
IOWA
I always labeled my tires on my 2010 Challenger when I changed between summer and winter tires, but not because of the sensors, but to be able to rotate them when I put them back on. It doesn't need to be marked for sensor recognition. Once you drive a block or two it will automatically register PSI and location.
Daw14
South Florida
The setup was changed in I believe 2013 maybe 14
rule18
Admin
NY
2017 Rebel
You don't need to mark them, the computer recognizes the new sensor location after a few minutes of driving (over 20 mph).
BOWERSFJ
Uniontown OH
My 2012 recognizes location .... I do summer/winter tires ... As mentioned above, You mark em so you know where to put em back on
misfit77
I didnt believe the tire shop, but on the 2014 its automatic.
Sent from my moto g power using Tapatalk
cdub5
