16WhiteQC
- Oct 17, 2016
- 518
- 423
- Location
- Hudson valley, NY
- 2016
- 5.7
I have had the 55w morimoto kit for years (basically since the truck was new on the relay harness) and I have had issues with (1) of the relays when it got cold out (common issue from what I read).
While I tried the replacement set once and again had issues once it got cold after a year or 2, I refused to buy more from them.
Instead I bought (2) of these - https://www.amazon.com/Bosch-Automotive-0332019157-Normal-Relays/dp/B00BJLIB9G/ref=sr_1_1?crid=6H0DHBKMXELJ&dib=eyJ2IjoiMSJ9.kYxgHM34PACRnkm7Sac-WwfHPBzkEYnpjbwSNCRUN6RZPfs_fsOeULLypYw-nW74bUIFlJuUF9oCkdrhLhj0bZC4bFsFD3TRkc0azQ3tgVE.AJ9OJ1GB8-Xmz-nu9Ge4kB1lumspuCTdSmbNlgc7Wvo&dib_tag=se&keywords=bosch+0332019157&qid=1736517180&sprefix=bosch+0332019157,aps,70&sr=8-1
I trimmed the tab off with a utility knife, pulled out the ****** mornimoto relays from the weather pack and installed the Bosch in their place - Problem solved!
So for anyone having issues with the morimoto HID kit (with relay harness) check your relays FIRST (swap from side to side and see if issue follows) and then replace the relays with higher quality ones!
