Tires rub
Skylernsthomson
6.7 cummins turbo diesel
I have a 2013 2500 with a leveling kit in the front. I need to get it about an inch and a half to two higher. What's the best way to do that if the level is already maxed out?
MADDOG
Living in a Firepit
6.4L HEMI
Body lift or full suspension lift.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
What exactly is your lift setup up front? On a 2500 there's many options to increase suspension height. You aren't near as limited as a 1500. No need for a body lift at all. They should NEVER be used on a 2500/3500 truck.
Ratket
Arizona-
what tire/wheel combo- setup are u running that it is rubbing???? 37"s? 35"s should not be rubbing- do us a favor before u post back post the tire size/make/model of tire and go measure them with a tape measure.. height and with. I don't care if the tire says 35-12.50.. actually measure them. Thanks this info will help us help u- also what lvling kit is it?
joshhhh
