Tool Box...
Steve Karolek
Pewaukee, WI
Cummins 6.7 HO
turkeybird56
Central Texas
^^^^^^^^^^ Nice looking product, not cheap... My only concern would be height/depth ref 5th wheel towing. U have to make sure U got the clearance. But that is a dynamite looking box, and make sure low enuf ref cover on truck when not towing.
Tonneaucovered
www.tonneaucovered.com
United States
N/A
N/A
Not a full tool box, but the Undercover Swing cases can lock and swing to the tailgate area.
Steve Karolek
Steve Karolek
Pewaukee, WI
Cummins 6.7 HO
Great point, one I had not yet considered. Obviously I need to adjust my filters... Thanks for helping me avoid a potentially costly mistake.
Steve Karolek
Steve Karolek
Pewaukee, WI
Cummins 6.7 HO
RVGuy
Alberta, Canada
I like it!
My only initial concern is that its height will be an issue with the 5th wheel electrical connections...
If it is, it wouldn't be very hard to make a short cord and put a plug on the forward side of the box for the 5er
Tumbleweed
Steve Karolek
Steve Karolek
Pewaukee, WI
Cummins 6.7 HO
When I had my 5th wheel, I bought a T harness that plugged into the factory harness in front of the bumper. I ran the female receptacle in front of the wheel well. That also allowed me to use a slide-in truck camper and still have the rear plug available to tow a trailer. It worked real well.
https://www.etrailer.com/t1-2018_Ram_2500.htm?fUrl=-sf-Fifth_Wheel_and_Gooseneck_Wiring
Thanks for the info. My truck came with trailer connections in two spots... next to the frame hitch (traditional spot) and inside the bed on the driver's side near the rear of the bed (for 5th wheel connections). My concern is that the tool box will prevent me from plugging into the connection in the box. I'll measure carefully, whatever I do.
bobeast
Hollister, CA
Hemi 6.4, 5.7
I had dual swing boxes in my last truck. They were worth every penny.
satxflhx
TEXAS
Cummins 6.7L HO
I'm looking for a locking tool box for my bed. Needs to fit under tonneau cover. Would prefer to be in the very back, at the tailgate, for ease of access without climbing in. Needs to lock since the cover will be rolled open while I'm towing my 5er. Thinking of the one linked below but open to any/all suggestions:
https://www.autoaccessoriesgarage.com/Truck-Toolboxes/UWS-5th-Wheel-Truck-Tool-Box
I was looking at the same box (and other like models) but also wanted to mount slide rails on bottom corners in order to pull the box out to the end of the tailgate when opened. Thus improving ease of access. The link below shows what I'm talking about. You can see the slides below the box with a locking pin on the left side.
https://www.google.com/search?q=5th...ECA4QBA&biw=1366&bih=625#imgrc=R8lhiUHBOTFfsM
runamuck
Air Force
dfw
6.7 dsl
a friend has that exact one and loves it. I checked it out and looks and feels solid..he has his up at the front of the bed tho.
Steve Karolek
Steve Karolek
Pewaukee, WI
Cummins 6.7 HO
Update, this is in fact the box I went with. Arrived within a week of placing the order, was very well packed (double boxed with protective padding between the boxes). I haven't bolted it down yet. Thinking about putting slides under it to pull it out out over the tailgate as described by @satxflhx
https://www.autoaccessoriesgarage.com//Truck-Toolboxes/UWS-5th-Wheel-Truck-Tool-Box
Saleen5150
