Tow/haul
fatelux2000
Atlanta, GA
2020 ram 3500
Having message popped up CHECK TRAILER BRAKE WIRING and TRAILER DISCONNECTED sign on my dash but all blinkers are working on trailer including break away kit...Any suggestions/advise will be appreciated
Travelin Ram
Probably a chafed spot or broken/loose connection in the trailer wiring. Have one person watch the lights and/or dash display while another goes through the trailer wiring harness poking and prodding. Or ask someone to drive behind you and see if the lights flicker.
I have also had the 7 pin connectors get dirty and make an intermittent connection.
Loudram
Just a sinner saved by grace
Navy Badge
South Jersey
Hemi 6.4L
I would also spray some contact cleaner into the plug and outlet then blow it out with some compressed or canned air or just let it dry for a minute or two. Also don't forget to check the connection behind the bumper (the back half of the outlet that's in the bumper).
The CRC brand they sell at Home Depot is good and plastic safe. That's what you need.
Also look for burn spots on the connector before you clean the connectors.
gofishn
Iowa
hemi 5.7L, 345 cu in
as mentioned, check/clean plug on th truck, front and rear.
clean trailer plug, inspect the trailer ground wire connection, to frame.
Then chase trailer wiring, from the plug, backwards.
One time, in band camp, (God I loved that scene)
my entire issue is was the tiny round connectors were too collapsed. stuck a small pick in one, opened it up,
did to each one and all my issues went away.
Made contact but as i went down teh road, the jarring would cause spllit second loss of contact.
took me hours to figure that one out, since everything looked perfectly fine. Now, its one of the first thing i check.
gofishn
Iowa
do us all a favor and some guy, eyars form now who reads this post.
tell us what worked, for you, in this instance.
392DevilDog
Glasgow, Pennsylvania
392 Hemi
If this is happening with a trailer hooked up, I would focus my search on the electric brakes.
It is the connection to them that alert the truck a trailer is connected.
So, the wire for the electric brakes, ground or even the trailer could be your issue.
Good luck. I am about to dive into fixing my trailer plug issues.
I have no running lights or 12v power.
F
fatelux2000
Atlanta, GA
I'm a new member in the forum and i really appreciate you guys respond to question very amazing...I will try it out and surely give a feedback to help others. Thank you 392devildog,gofishnLordram
John Jensen
San Diego County
Ecodiesel
DevilDog is right on about the trailer brake circuit. Therein lies your problem. The blade type plugs are notorious for losing contact.
