Tpms question
RamRod302
Pleasant prairie Wisconsin
4.7 ho
I picked up an 08 1500 that has been sitting for 3 years so naturally the tires are shot and the valve stems corroded. My question is what Tpms sensor do I need to look for to replace them, and then my next question is do I need a scan tool to get them to work. Thanks for any help you can give me.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
You should have the 315 tpms sensors not the 433 but you should see what is actually inside, it should have it stamped on the actual sensor ...
and you shouldn't need a scan tool either ...
aeromax4
Brookhaven, Pa
Question, I'm looking to upgrade my 18" stock wheels for 20" factory on my 2020 Laramie 1500. Can I reuse the TPM sensors from my 18" wheels or do I need to change them? Will the computer require updating to the 20" wheels? TIA for any help.
HemiLonestar
Navy Badge Coast Guard
MD
Sensors will work fine. As long as you don't change the overall tire diameter you don't need to do anything. FYI you have a 5th gen, this topic was for a 3rd gen.
