I had my enclosed trailer serviced yesterday. My dealer is very reputable and does great work. They replaced my four electric trailer brakes and a couple fender lights along with the pigtail cable. All worked well until 7 miles from home when the display gave me check trailer brakes and then? Trailer brakes disconnected messages. My trailer dealer told me newer trucks are very sensitive to truck or trailer wire corrosion. When I told him that when hooked up with my four ways flashing, that the interior led lights were pulsating with the four ways, he instantly directed his focus on the truck wiring. He asked my yo clean the ground and the 7 pin connections.
Questions. Where is the ground for the trailer plug connections so I can check for corrosion and clean?
Has anyone else had their truck disable the trailer brakes and how did you fix the issue?
Thanks
Thanks
