Transmission pan replacement
demonram
Just wanting some feedback on replacing my transmission pan. 2011 1500 Sport with 5.7. I will be changing the transmission fluid and filters soon. I'm wanting to replace it with a pan that has a drain plug. I found one on Amazon, it's an A-Premium pan with drain plug. The add shows it to be compatible with the 1500 with 65RFE, 68RFE, and 545RFE transmissions.
Has anyone on here replaced their pan for one with a drain plug, and if so which pan did you use?
Thanks for all feedback.
