Jared Worley
- Aug 22, 2018
- 109
- 39
- Location
- Columbus, OH, United States
- 2009
- 5.7
I am in need of some help. My truck is an 09 5.7 2wd. I swapped a 5.7 and trans from a 2013 with required part changes. I also swapped a mild 2600-2800 converter. It was running great but stuck in 4th because the solenoid pack is not compatible.
The issue, after the shop swapped the correct 04+ "remanufactured solenoid and valve body" that I supplied, they described the truck shifting too quickly. I was told that now the truck is stuck in second gear no matter where the selector is and won't let the truck start. There are supposedly no codes. Did battery disconnect in case WCM lockup was preventing start. Did I get a bad solenoid or valve body? Something else to check?
