Truck won't go into gear? Need help!
rwalk
Westford, MA
4.7L V8
So yesterday morning I went to go somewhere and I turned on my truck and put it in reverse, but when I stepped on the gas the engine only revved and I did not move anywhere, the same thing happens in all gears. I've tried multiple times throughout the day yesterday and its still happening. Only thing I did to try to fix it was disconnect and reconnect the battery which didn't work.. Any idea on what may be wrong?
scHemi
2009 RAM SLT Crew
Transfer case in nutreal
rwalk
rwalk
Westford, MA
4.7L V8
The only way I would know to check that is the light where I can press neutral in the same panel as my shift-on-the-fly but that is off.. We tried getting it to go in 2wd, 4hi, and 4low but no luck at all
scHemi
2009 RAM SLT Crew
That would be the only way I know how to check it too. Lite off no neutral. Drive shaft still connected?
rwalk
rwalk
Westford, MA
4.7L V8
As far as I can tell yes.. I drove it the other day it worked perfectly fine then the next morning I tried to leave and it just wouldn't go..
Hemi395
Cape Cod MA
Somewhere on here I remember reading a thread about this same issue and it turned out the shifter linkage came undone at the transmission....
Sent from my HTC EVO 3D using Tapatalk
rwalk
rwalk
Westford, MA
4.7L V8
The truck got towed via flatbed to the dealer this morning, so we will find out soon
scHemi
2009 RAM SLT Crew
I can't wait to hear
badjuju2010
Sounds like a shifter linkage
Sent from my DROID RAZR using Tapatalk 2
rwalk
rwalk
Westford, MA
4.7L V8
Got the truck back today, bear with me on the description since this information has been relayed between a few sources before it got to me, and my dad said he was only half listening.
From what I was told, the dealer originally said that the whole transmission was garbage and that it wasn't covered by warranty because I have taken the truck off road. After the guy from my shop did some negotiating with the dealer, who he had connections at, they took a closer look and turns out that some filter within the transmission was either blocked or disconnected causing the issue, and they ended up covering it through warranty.
Again, bear with me as I will be getting some more info on the problem within the next day or two when I go back to the shop.
No matter what it was, I'm glad it is working again and even better, that it was free!
Orca
