TT/Supporting mods suggestions...
4eyedconekiller
North MS
EcoDiesel
About to be a first time travel nurse, and contemplating making the plunge on a a travel trailer right off the bat.
I have No money reserves, but hate the idea of giving away half my stipend and having very little In return. Looking at an assignment with variable hours, so it would be difficult to have roommates.
Looking for a 20-27’ TT. 5K# or less dry. Pulling with my EcoDiesel. Traveling solo.
Already looking at adding airbags, buying a WDH, and making sure brakes and shocks/struts are in good working order.
Suggestions? Thoughts?
Ohio5pt7
Ohio
Your on the right track. 5k or less will be no problem for your truck imo. Mine is a 26.5ft bunk house weighs about 7500 loaded. Taken thru mountains hills the whole 9 no issues. My truck is a cc 4x4 with 3.21 gears and a hemi. Wdh with stabilizer bars is a must if you ate traveling a lot. Airbags would likely help you even with a 5k lb tt as I assume living in it your going to have a lot loaded up. Upgrading tires will help some with sway. Best thing to do is take your time and remember you towing a 20+ft sail that weighs as much or more than your truck so it is gonna move you.
Sent from my SAMSUNG-SM-G891A using Tapatalk all grammar errors brought you by fat fingers and auto correct.
Travelin Ram
Make sure you do the math on camping costs, RV parks are not free. All in, your costs to live in an RV can easily equal a small apartment, depending of course on what region you are in. It’s not impossible to save money, but it’s not guaranteed either.
A good WDH is really all you need, I’ve towed plenty of TT in that size range with various pickups and SUVs.
Living on the road with no financial reserves would give me pause. Stuff happens.
Most trailers are not built to withstand the wear and tear of continuous occupancy. The materials are cheap and thin. Doesn’t mean it’s not possible, just be prepared for maintenance.
If you have RV’d before, you probably know these things. If this will be your first experience, tread carefully.
Best wishes on your new career direction.
NewBlackDak
6.7L Cummins
You don’t have to do anything special for a trailer that size. A good weight distribution hitch with sway control, and keeping up with maintenance would serve you fine.
No cash reserves is a worry. Things do and will break that can be a minor annoyance for a short trip, but become big issues when full-timing. Most small campers don’t hold up well to full-timing, and those that do aren’t cheap.
Not to discourage, but consider all the possibilities.
4eyedconekiller
North MS
EcoDiesel
For sure. That’s why I am trying to stay lighter. Kinda anxious to see how the EcoD does with that kinda load.
I’m just now doing some digging around. Exploring all options. I’d prefer to buy a used nicer one than a cheap new one. Time will tell, for sure.
Thanks all for the wisdom!! I really do appreciate it.
Reserves: I’m actually looking to work for a few weeks to get some cash put back, and then pick up a TT.
I did however find one of these for a STEAL: https://www.rvusa.com/rv-guide/2020-gulf-stream-conquest-travel-trailer-floorplan-275fbg-tr44729
Nice layout, no extra slide out stuff. Little heavier than I was looking at, but it’s a dealership that’s closing. Can buy for 10,500.
Toddbigboytruck
Ontario
Congratulations with your new life choice I hope all the best for you
I think with what you have stated that you have a good head on your shoulder.
Now here is my 2 cents yes but used you save so much we have bought three trailers and every time we bought light use and had them until we out grew them
Towing well not knowing your configuration on your diesel rear end and your towing capacity but staying under 5000 lbs will be great
I would look into RV Care. It is like AAA for your trailer (I understand that money is a issue)
I hope you all the best and congratulations
csuder99
As you will be living in the trailer do yourself a favor and do a lot of research into travel trailers, especially construction details, durability, cold weather capability, reputation of manufacturer. The trailer mentioned above is tempting, especially at the price, but a dry weight of 4738 lbs with a length of 29'10" is kind of a red flag in my book. In comparison 25ft four season trailers come in at ~6000 lbs dry weight.
OC455
Central NY
I would look into the Keystone Premiers. Aluminum frame, aluminum framed walls, and insulated. If it was just me and my Missus, I would have the 22RBPR. Look at the 19ft or 22ft models. Might be better than the 27ft one you are looking at. Having the feeling of white knuckle ride with a large RV/travel trailer will make ya tired for sure over long distances. It might be some more money, but they look to be better built. My $0.02....
4eyedconekiller
North MS
EcoDiesel
I really appreciate it. This forum is such a good wealth of knowledge!
I will continue to dig. This is why I ask - I wanna learn! I’d have never known to look at it like that.
I will for sure look into them! Thank you!
RVGuy
Alberta, Canada
If you set up your wdh properly you won't need airbags. Airbags hide problems (and sometimes make them worse in the process) because they don't redistribute weight in a beneficial manner, if at all.
In terms of trailer, living in them is no easy task. They aren't meant to be, and it'll show. It's possible but you'll need to spend some time and money on the way. A good 3 season trailer is a good place to start but they're not light or cheap. Northwood is a good starting point, they make Arctic Fox, Snow River, and Nash travel trailers. Their sister manufacturer is Outdoors RV and they're also good. Montana is another go to trailer for people, Cougar, Winnebago is getting into the trailer game now too if you can find a good used one already.
What you need to do to make them liveable full time will depend on where you plan on living. Do you expect to see freezing temperatures often? Are you going to be moving around a lot? Will you always be plugged in to dependable power/water supplies? Are you going to have a dump station at your site? Will you be running off the small onboard propane cylinders or rent a larger 100lbs tank?
No matter what though, my main suggestion is if you plan on using the propane furnace you absolutely need to invest in a good dehumidifier. I cannot tell you the amount of trailers I've written off because mushrooms were growing in the carpet or between the walls of a lived in RV. The furnace kicks off a lot of moisture into the air and high humidity is not an RVs friend.
4eyedconekiller
North MS
EcoDiesel
I’ve been digging for months, and decided to hold off on both the KTM and the TH. Decided to go forward with a regular TT.
Think I’ve found a winner...
[/URL]
5355# Dry, 7500# GVWR, Hitch weight 630. Includes WD Hitch and all the expensive bits that come with starting a camper adventure. Second owner, no repairs. WInterized religiously. Arctic Package, Electric Jacks, etc.
Pics:
Thoughts? Anyone had one of these???
RAM DRVR
Mid left coast - Oregon
CTD
Looks good. Ask/make sure wheel bearings have been serviced. Operate everything several times to ensure they work properly.
ramffml
ramforum
I think that's going to be too heavy for your truck. 7500 dry, so 8500+ with cargo (probably a lot more if you're living in it and collecting things as you go, or have water in your tanks + propane on board etc). 8500 * 0.13 = 1100 pounds of payload.
For a 4th gen ED, that's probably already right at max payload (my brother's ED has < 1000), and you haven't even climbed in yourself yet.
You may be able to make it work, but considering you plan to do this permanently and often, I personally would go smaller (or trade your truck for a used 2500 hemi).
4eyedconekiller
North MS
EcoDiesel
As far as I know, they’ve never been serviced. It’s currently still apparently got the original tires on it. Date code 4313.
Maybe I’m reading the specs wrong, but it’s got a 53xx# dry weight, with a payload rating of 2145#, and a tongue weight of 630#. Truck is rated at 7600#. Fully loaded, I agree it would be a lot. As a travel nurse, I have a place full of stuff at home. I will travel with minimal tank fills and will be parked while I am on assignment. The jump to 8500# in your calcs is throwing me off. How does that correlate?
I have a lot to learn, so I’m asking questions to make sure what I’ve got my hands on.
4eyedconekiller
North MS
EcoDiesel
here’s the chart for the EcoD...
4x4, CC, 5.7 Box, 3.55’s
392DevilDog
Glasgow, Pennsylvania
392 Hemi
He read your post wrong.
Good luck. It looks like a winner if everything checks out.
Safe travels.
392DevilDog
392 Hemi
GCWR 13500
GVWR 6950
Camper 5335 TW 630
What is your payload on your door sticker...so I can figure your base weight?
You will have to tow with the tanks empty...but you can fill and dump at a campground.
ramffml
ramforum
My bad, I did read your post wrong, I thought the 7500 was dry weight.
