392DevilDog
- Aug 25, 2019
- 1,940
- 2,903
- Location
- Glasgow, Pennsylvania
- 2015
- 392 Hemi
Cool. 1160.
Curb weight is GVWR minus Payload.
The max towing figure is a bit deceiving. It is GCWR minus Curb weight. Which as you see...doesnt provide a driver or a hitch.
So 6950 minus 1160 is 5790
13500 minus 5790 is 7710. 7710 is everything you can combine to your truck.
So you said the UVW of the trailer is 5335 with a TW of 630. So you got the trailer of 5965. Remember...this is the least your trailer will weigh.
A WDH is usually about 100lbs. So. 6065 is at the back of your truck.
TW is part of payload. 1160 minus 630 and the 100lbs hitch is 430lbs left for your truck.
So that would be the room for you and anything you put in the truck. But...you have room to put things in the trailer.
So lets say you put 1000lbs in the trailer. That is only about 120lbs added to the truck. Which allows you to have 310lbs in the truck.
When you hook up the weight distribution hitch...you will distribute the weight and be fine.
And there is a bit of capacity left ...just be sure to get weight back to the steer axle
Hope this helps. Hope the numbers make sense.
Any questions just ask.
I think you will be fine towing that trailer. Keep the speeds safe and prepare for any hills or mountains. You got a good combo there.
