Go to the following URL then look about half way down the page: https://www.obd-codes.com/u010c or https://carscounsel.com/u010c-code/My 2018 has the code U010C. It seems to be running fine, maybe a little bit underpowered. I can build 15 psi boost empty.
What can I do to diagnose/troubleshoot this problem?
My exhaust brake quit a couple months ago.Most likely your actuator is failing, that's a pretty common code when it starts to go. You will probably lose the exhaust brake all together soon.
When it goes I would suggest the City Diesel replacement actuator, it's built beefier then the stock actuator and does not require alignment so you can replace it yourself.
Is the turbocharger control module the same thing as the actuator or is it something else? If it’s something else what and where do I need to look on a 2018 Ram?
What is your thoughts on the turbo possibly being bad at 175k miles causing the actuator to fail, also I have been driving for a couple of months this way.
I’m not wanting to spend more than I have to but I also want it to last. I’ve read a lot saying you can put a new actuator on and it might last a month or maybe even a year. As I said I really don’t want to spend more than I have to but don’t want to waste $1000 if it will last only a year or less.
BTW when was the last time the EGR was cleaned, If hope you followed the advice for trouble shooting at the second URL I gave you above, if not then you then have 2 choices take a change an just the actuator or buy a rebuild turbo that has a new actuator like the one from City Diesel, the one they sell is plug & play no code updates needed...Well I might just roll the dice and claim they said actuator was bad. I really don’t think the turbo would be too gummed up since this truck is mainly highway driven and whenever I do idle it I idle it up.
The truck has more miles than I was thinking, it has 183000. I bought it February 13,2024 with 123k on it. It rarely pulls or hauls anything.
