Upper Glove Box Install
JCJ4290
2014 CC 4X4
Anything is possible, just not likely. It may be wrapped or pushed to the back. And I assume you're talking about the light harness. As said before, all of the ones with uconnect should have the USB plug.
Is it possible that on the ST that they did not do the wiring harness? I have looked all up in there and can not find it.
JCJ4290
2014 CC 4X4
Gotta remove the screw holding it in. One under it you have to access by removing the lower glove box and then pull it out
monte07
Oceanside, NY
Did this upgrade today on my '13 Express. You do need patience lining the door up but other than that it was a piece of cake. The plug for the light was exposed and I didn't need the USB. It really finishes off the interior.
Thanks to trmat79 for the original write up.
345growler
Ozarks AR
May-13
One thing that drives me ape nuts is things flying around the cab ......always if you drive that hemi!
dracman
canada
2017 black out edition
yup i did it to but i tested the switch with the bulb in and it works.pluged it into the truck dont work.guess have to check for power comming off wire of truck.besides that love it
Warmage
any one knows the black door part number ?
GiJoeFontaine
Lower Mainland, BC, Canada
2019 Classic
FINALLY found a upper glove box. I'm in BC Canada and got it from a wrecker in Vancouver Washington lol. $50 USD complete shipped to my door. Instead of $150+ here in Canada. Even with the exchange I'm winning!
I'll get on the swap this week I hope!
Jems007
