Warn Winch Clutch Location?
TennVol
Knoxville, TN
I have a 2018 PW. The winch has never been used, so today I thought I would try it out to get the feel of how it works. I immediately ran into a problem. I can't find the lever to disengage the clutch. The remote works just fine reeling the cable in and out. All of the instructions I can find reference the clutch lever. I've been under my truck for 20 minutes looking for the darn thing, but can't find it. Can anyone point me in the right direction? Thanks!
wobly
Colorado Springs, CO
2021 Ram 2500 Power Wagon
It should be accessible from the front. If you are standing in front of the truck, just reach your hand in the hole by the passenger side (curb side) of the winch. The lever should be in there.
LeesEvoX
Houston, TX
Hemi 6.4l
Watch this video. Skip to about the 1 minute mark.
Should just be to the right of the winch iteself.
Hope this helps!
bm02tj
B C Canada
If you have never used this respool the cable or rope under tension before you use it
If steel cable I would use fluid film on it as you spool it makes it last longer only down side is your gloves get dirty when you use it
Daw14
AAA is your friend.
TennVol
TennVol
Knoxville, TN
Thanks for the tip. I'll pick up some today and spray it on the cable as I'm re-spooling.
